Hello,
I’ am having a very hard time trying to determine what size of a monitor or monitors to get? My main one as you will see on the link below is a Dell 24" 2407WFP-HC my original thoughts is ether get 2X 22” inch monitors and place them on both side of my main one, or gat one 24”. My budget is not that crazy because I also need to get one for my younger brother and having a hard time deciding what to get him as well… If I would to get 2X 22” monitors for myself, I was thinking about $170 each, newegg has some interesting choices. However If I would to go for one 24” I would spend about no more then $270 as I don’t believe spending more on a single secondary monitor is needed. I am linking some pics for you to see how my current setup looks like. I’m kind of leaning toward getting a 2X 22” monitors, but very interested in your feedback. Main usage for the extra monitor’s will be probably playing WoW (yes I know, I’m a lost case). The pics are few month old, but the current layout is about the same.
http://i101.photobucket.com/albums/m62/MALOI2006/DSC06033.jpg
http://i101.photobucket.com/albums/m62/MALOI2006/DSC06037.jpg
Also what adapter do I need to get in order to have 3 monitors hooked up? And what type of a layout am I looking at with 2 addition monitors, Will I be able to extend it on both the left and the right? I currently have one 9800GTX.
Thanks
Thanks
