Can't click on links
Status
Not open for further replies.
This was a DNS issue that was on our end but was fixed a week or so ago.
Might try flushing your DNS cache.
The following methods allow you to remove old and inaccurate DNS information that may result in 404 errors.
Windows® 8
Press Win+X to open the WinX Menu.
Right-click on Command Prompt and select Run as Administrator.
Type the following command and press Enter: ipconfig /flushdns
If the command was successful, you will see the following message:
Windows IP configuration successfully flushed the DNS Resolver Cache.
Windows 7
Click the Start button.
Enter cmd in the Start menu search field.
Windows XP, 2000, or Vista®
On the Start menu, click Run....
If you do not see the Run command in Vista, enter run in the Search bar.
Type the following command in the Run text box: ipconfig /flushdns
MacOS® 10.7 and 10.8
Click Applications.
Click Utilities.
Double-click the Terminal application.
Type the following command:
sudo killall -HUP mDNSResponder
ALERT! Warning: To run this command, you will need to know the computer's Admin account password.
MacOS 10.5 and 10.6
Click Applications.
Click Utilities.
Type the following command: sudo dscacheutil -flushcache
Status
