Can't change display resolution
Chaoss
My monitor (actually a tv) has a none-standard resolution of 2560x1080, meaning I have to make a custom resolution in the NVidia control panel, now I would do this but it appears a bug in the nvidia control panel software is preventing any resolutions from being displayed. In the change resolution window there are no resolutions displayed, refresh rate and colour depth dropdowns contain no selections, I was wondering if there is a way I can manually add it in. Using an alternate monitor does NOT solve the issue. Anyone here have any work arounds?
I have never seen a 2560x1080 TV. I'm curious now...
You're certain it is definitely 2560x1080 and not 1920x1080?
2560x1080 is a panoramic resolution so the TV would be very wide.
