scoobz0202
- Nov 2, 2006
Hey,
I have the Optiarc DVD RW AD-7170A
I have used a couple free dvd burning softwares but I always get errors. Here are a couple.
dvdSanta:
Error Trace
KEY,ASC,ASCQ,ASCLEN=5,30,10,a
BurnAware
BurnAware - DVD-Video [2/5/2008]
D: Optiarc DVD RW AD-7170A 1.02
C:\Documents and Settings\Chris H\My Documents\DVD\dvd\VIDEO_TS
[4:15:04 AM] Preparing data
[4:15:04 AM] Burn process failed (A Device Error occurred during write.)!
[4:15:04 AM] Total time:
Then with Nero i get this massive log:
1a2001000000240846965452
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 11:35:32 AM
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15e
(Nero Express)
Recorder: <Optiarc DVD RW AD-7170A> Version: 1.02 - HA 4 TA 0 - 6.6.0.15
Adapter driver: <JRAID> HA 4
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <Optiarc DVD RW AD-7170A >Version: 1.02 - HA 4 TA 0 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD3200YS-01PGB0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Optiarc DVD RW AD-7170A 1.02 JRAID Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7170A D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096300kB)
Free physical memory: 1100MB (1127176kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
5.2.2008
ISO compilation
3:55:14 AM #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
3:55:14 AM #2 Text 0 File Reader.cpp, Line 127
Reader running
3:55:14 AM #3 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
3:55:14 AM #4 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using DVD media
3:55:14 AM #5 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 378127 ( 84:01.52, 738MB)
3:55:14 AM #6 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
3:55:14 AM #7 Text 0 File DlgWaitCD.cpp, Line 2457
Recorder: Optiarc DVD RW AD-7170A, Media type: DVD+RW
Disc Manufacturer ID: RITEK, Media Type ID: 004, Product revision number: 48
Disc Application Code: 0, Extended Information Indicators: 1
3:55:14 AM #8 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
3:55:14 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 378128 (378128) = #378128/84:1.53
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 378128 blocks [Optiarc DVD RW AD-7170A]
3:55:14 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [Optiarc DVD RW AD-7170A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 774406144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
378128 | lead-out | 1 | 0x41 | 0x00
3:55:14 AM #11 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
3:55:15 AM #12 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
3:55:15 AM #13 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
3:55:15 AM #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5,540 KB/s)
3:55:15 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:55:15 AM #16 Text 0 File Cdrdrv.cpp, Line 8821
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Disc Manufacturer ID: RITEK...
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 52 49 54 45 4B - 00 00 00 30 30 34 30 39 ...RITEK...00409
23 00 9C 81 5C 02 28 00 - 96 8A 70 02 28 00 9C 81 #...\.(...p.(...
68 02 28 04 04 20 E0 00 - F0 00 00 00 00 00 00 00 h.(.............
3:55:15 AM #17 Phase 98 File dlgbrnst.cpp, Line 1832
Start formatting disc before burning
3:55:15 AM #18 SCSI -1065 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x038A6000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0x04 0x11 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x20 0x00
3:55:15 AM #19 Phase 101 File dlgbrnst.cpp, Line 1832
Formatting disc failed
3:55:15 AM #20 Text 0 File DVDPlusRW.cpp, Line 663
Start write address at LBA 0
DVD high compatibility mode: Yes
3:55:15 AM #21 CDR -1065 File ThreadedTransferInterface.cpp, Line 1763
Invalid command
3:55:15 AM #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1763
Could not perform start of Disc-at-once
3:55:15 AM #23 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 8/24/2006 10:47:00 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 7/25/2007 9:53:30 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\jraid.sys': Ver=1.12.07.00 built by: WinDDK, size=43904 bytes, created 8/4/2006 4:29:24 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
dvdSanta:
Error Trace
BurnAware
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
5.2.2008
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Media type ID: 004
Sense Code: 0x20
Sense Qual: 0x00
Invalid command
Existing drivers:
Registry Keys:
