Can't Burn CD's
shizdan
i Cant' burn cd's Even when i use multiple programs..
1- Right now im using nero but everytime i go to burn a cd it says for Current Recoder-Image Recorder
2 -Then when i hit "Burn" it goes to the next menu and "save Image File" comes up.
3- When i save it to "desktop" i go to my desktop and its a saved as a Disk image .nrg
The Burner is a ASUS DVD-E616P2
image record records just that, an image of the disc on your harddrive. If you can, switch the recorder to one of your optical drives, the option is in the menu or toolbar somewhere.
In my version of Nero, CTRL-R allows you to choose the recorder. Select your optical drive and you should be good to go.....:cool:
