I have WindowsXP installed on my SATA drive, and have a blank ATA drive. When I set the SATA drive for boot, it doesn't recognize a bootable disk. It makes me put the blank drive as boot. w.t.f...?
[H]ard|DCer of the Month - February 2007/January 2
What was the boot order in the bios when you installed Windozes.
If your SATA dive was second then your boot.ini files, rtc will get installed on the other drive.
I now always disconnect all my other hard drives when doing a new install of Windozes for that reason.
Once installed I then connect all my other drives.
Then move my cd drive from D: to N: to make room for the hard drives.
So easiest way if its a fresh install is to just reinsall without anyother hard drives.
