last_caress
- Oct 14, 2014
I currently have a bootable CD(ESXI installer), and 2 bootable HDD's installed (Win7 and ESXI).
When the RAID card is connected my system will freeze at _ and indicate it cannot boot (insert a system image) if booting from the CD
If booting from the ESXI partition it loads almost everything, but then hangs on something to do with the Kernel.
Similarly if I try to boot from the Win7 HDD it will not be able to boot and either hang at _ or boot the ESXI partition.
If I disconnect the RAID card I can boot from any of the devices without issue.
I've tried booting from the RAID controller and from the motherboards SATA ports and I"ve also changed the drives to bootable in the RAID BIOS, disable SATA ports not being used in BIOS (particularly the ones that have a Software RAID capability). None of this seems to work.
Anyone have any suggestions? I've spend days trying to figure this out with no luck.
Motherboard: GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Processor: Intel Core i7-930 Bloomfield Quad-Core 2.8GHz LGA 1366 130W Desktop Processor BX80601930
RAID Controller: IBM ServeRAID M1015 SAS/SATA Controller
