I'm trying Stilt's custom BIOS for the R9 290's. I previously used the PT1T BIOS. In afterburner I can't increase the core clock past 920. If I do, the core clock drops and fluctuates around 890. I had the same issue mining with the stock BIOS. Everyone else using his BIOS seems to be running at 1000-1100 core just fine.
Also, I can't change the core clocks using the scrypt config for this particular rig. I don't know why. MSI afterburner was always what worked for me. I put in --gpu-engine and none of them change clock speed, even the ones with the PT1T BIOS.
The card is under water.
