Canon XTi or Sony A100
Stinger1
I've been reading up on these two, but I want to ask you which would be the better camera to buy.
I would get the Canon simply because it'll give you more options in the long run for lenses and accessories.
Both are very comparable for image quality. Feature wise I would give the edge to the Sony. But that still wouldn't stop me from getting the Canon.
If you haven't actually picked one up in person before, I would HIGHLY recommend holding the cameras in person before making a decision. Ergonomics should be at the top of your list of reasons for making a decision. Followed very closely by lenses.
You might also look at a Nikon D40x or Nikon D80. It's in the same range as the other 2. Also in that range is a Pentax K10 which beats everyone featurewise.
In short. Feel the cameras and look at the lens lineup.
xti without a doubt. you will not regret it, and later on down the road you will have a great selection of lenses and acessories.
I'd get Canon simply because of the name over Sony.. I've never liked the sony P&S cameras I've seen, although I personally have only ever owned Canon cameras, as has my mother when she used to use SLRs when she was younger.
I have an XT and I absolutely love it. The first day I had it I was simply amazed at the image quality even at 1600ISO. I've never looked at what Sony has to offer, but Im sure Canon has a wider range of DSLR lenses as well, and accessories.
Canon gets my vote.
-Edit-
I should add that I never actually gave very many DSLRs a chance when I was first shopping around for one.. Since I was completely set on getting a Canon regardless, just wasnt sure what model to get. If I were to do it again, I would look closely at the Nikon D40 and the (new?) D40x, as well as a few of the higher end Canons and Nikons. Depending on what you plan to do with the camera, getting say, a D30 body might be more wise than getting an XT kit. It also depends on if you have any lenses available through friends and what not. I also made my Canon purchase because I thought I had access to older lenses from my mother, but hers were the mounting before the EF lenses that Canon uses now. But whatever, I still love my camera.
the rebel xt and xti are quite the same
canon has a strong name in cameras and camcorders
i bought an XT and HV20 on the same day
HV20 is the best consumer camcorder (HD) available and rivals prosumers to pro
Oh, that's easy, a Nikon D80. ;)
Don't get a Sony, they have no serious photography following. I would suggest taking a look at the D70/D70s/D80 and the XT, and XTi - those are the 2 brands/models you should be looking at for the best future usability and quality for the price. Do NOT look at a D40 if you want to get serious. They are great cameras for the money, however they run a seperate kind of lens mount, and you won't have but 2% of the total pool of lenses available to you - if your comparing the XT to the D40, you might want to get the XT (can't believe I just said that). But, you can get yourself a nice used D70 for around 600 if you spend your time looking (that's including the nicer 18-70mm lens) and a D80 around 800-900. The advantage to the D50-D80 series is they can use all nikkor lenses all the way back to 1959... literally hundreds upon hundreds of lenses to choose from - and very affordable.
Well, it's not that they (Nikon D40) use a separate lens mount, it's that it uses the Nikon F-mount, but Nikon removed the autofocus servo on the camera itself, so you can only autofocus with AF-S/AF-I lenses. Still, it does severely limit the pool of lenses you can use if you want autofocus.
Personally, I'd recommend a Nikon or Canon, they both have great lenses (I still pine for an equivalent of the Canon 70-200 F/4L). Sony's A100 is pretty much a successor to the Konica Minolta line, but I have zero experience with them.
In this case I'd go with an XTi, even if it's a little smallish, but I have giant hands. :p
Just get the BG-E3 grip for the XT/XTi and it alleviates any small/large hand issues. Plus it adds the 2 battery capability and makes it easy to take vertical shots with the extra control buttons.
Well since you want to choose between the two. I would suggest the Cannon despite my being a Nikonian. As was said you will have alot of lense choices and, other accessory choices.
You guys have me thinking anyway. I am now looking at getting a Canon XTi or a Nikon D80. I really like the D80.
A new question.... How important is having built-in image stabilization? The XTi doesn't have it. I'm not sure about the D80.
The D80 does not have IS in camera. I cant speak to wether the XTi does. Nikon makes Vibration Reduction lenses for some of their zooms. I have the 80-400mm VR myself but, it isnt cheap, it cost me $1400 but, I love becuse I can shoot at 400mm hand held and, get better results. I still use a tripod most of the time though. Tripods are still necessary in low light.
I know Cannon has gone VR in camera on some models but, I prefer the per lense approach. The best of both worlds would be in camera and, in lense selectable in my view. I have a D80 and love it but, it took me a little while to get that way. I had to learn more to use it than I did with my D50.
XTi doesnt have in camera Image Stabilisation. They have the IS lenses for that. You cant really go wrong with the XTI or the D80. I prefer Canon stuff, but thats just because i started on canon. There are pretty much unlimited resources for Canon users out there.
