Which one is better?
I'm ordering one from Apple.ca and they include a $130 mail in rebate.
Both cost 149.99 (but over at Apple.com the MP470 is cheaper)...
The advantage that i see the MP470 has is that it has higher scan resolution (optical), smaller and has a color LCD screen.
The MX310 on the other hand has a fax, much larger, and apparently its more bang for buck (even though they cost the same at Apple.ca
What should i do? I need a multi-function printer and there are no HP one's available at Apple.ca
