RedWagnum
- Mar 30, 2007
Cannot Wake System With Kbd/Mouse
Hi yall!
I've been trying to troubleshoot this for a few weeks now and it's driving me nuts! It's not a huge issue but I want to make it work like it should.
Whenever I put the system to sleep (S3 sleep, hybrid mode [hibernate] is disabled) the only way I can wake the system is with the power button on the case. I cannot use the mouse or keyboard to wake the system. This started after upgrading from an ASUS P5K Deluxe WiFi / E8500 to an ASUS P8Z77-V LE Plus / I5 3570K. Other hardware as is in signature. With the P5k this worked perfectly, I could wake the system with the mouse, keyboard, or power button. Now with the P8Z77 only the power button will wake the system.
After installing the new board/CPU I installed Win7x64 on a new Samsung SSD. After discovering the problem the first place I went to look was Device Manager > Keyboards > HID Keyboard Device > Properties to check the power management settings. Well guess what? There is no power management tab...
Check the mouse, same thing...
Maybe something to do with the root hub?
Well here I at least have a Power Management tab but the "Allow this device to wake the computer" is greyed out. It is like this on ALL the root hubs and ALL the Generic hubs.
I thought it might be something I missed in the BIOS Setup. There are five options in Advanced Power Management (APM)
Restore AC Power Loss, Power On by Ring, and Power On By RTC are irrelevant to this. Deep S4, as indicated in the help text, only allows the system to awaken by the power button when enabled. I've tried it both ways and there is no change. Power on by PCIe/PCI seems to only apply to the Ethernet adapter (which has the Power Management tab fully available in Device Manager).
So what the hell am I missing? On a whim yesterday I temporarily installed a single 500GB hard drive and installed Windows from scratch thinking it might be a driver issue or something. Installed Windows, installed the LAN driver, installed nearly 200 updates (NO DRIVERS), then downloaded the latest Intel Chipset Installation Utility from Intel and installed that.
Exactly the same result - no Power Management tab as above.
Some searching led me to Power Options > Edit Plan Settings > Advanced Power Settings > USB Settings > USB Selective Suspend Setting (which I disabled) and PCI Express > Link State Power Management (which I turned off). None of this changed anything.
I don't know what else to try. Anybody have any suggestions?
Hi yall!
