Cannot run advanced benchmarks in 3D Mark Advanced Edition
bobthfd
The dialog for all of the advanced benchmarks in 3DMark Advanced states that "My hardware is not compatible for the test" and that the test requires a DirectX 11 GPU. I'm running a pair of GTX970's in SLI. The Preliminary benchmark will run and it does detect my cards, DXDiag shows I'm running DirectX 11. When I try to click on the configure link for the advanced tests I get a pop up telling me I need the advanced version, but the title bar and the help page confirm that I am running the advanced version. I didn't have any problems until I upgraded my Mobo and CPU. Any ideas?
Sounds like 3DMark is confused after the hardware swap. I would suggest uninstalling it and reinstalling. What version of windows are you running? I take it when you did the mobo and ram swap that you didn't reinstall windows or graphics drivers?
Good point about not having done a fresh install of Windows. I was hoping to avoid doing so but it may be worth the effort if this is the first sign of complications
