Hello,
I've been tearing my hair out trying to get an OS up and running after my old hdd crashed. I have brand new copies of vista ultimate and xp pro sp3. I formatted my 320gig hdd w/ the xp install disk, but when i returned, it appeared to have restarted (after finishing the format?) and said 'Disk Read Error Ctrl+Alt+Del to restart'. After restarting, it attempts to boot off the CD and after briefly flashing "Setup is inspecting your hardware configuration" the screen goes black and nothing happens for at least 10 minutes. After formatting, installing, and repairing with Vista, it restarts and gives the same disk error. I've run Memtest 86 on the memory (which i have to downclock to 333Mhz) with no errors. At 400Mhz some errors pop up. This is an old problem which I had fixed just by downclocking. So, either way, after attempting to install either xp or vista, the machine refuses to boot an OS. I've run full scandisk checks and tried this whole process on 2 hdds, both of which have no errors. I've cleared the CMOS several times between attempts. Here is a list of the hardware involved:
Abit KV8, AwardBIOS v6.00PG
Sempron 3400
OCZ PC4000 1gig Gold Edition GX XTC (3-4-3-8) 1024 EL DDR
BFG GeForce 256MB 6800 OC AGP
WD3200 (320gig)
WD1600 (160gig)...I swap this one out w/ the 320 seperatetly and get the same problem
LITE-ON DVD player SHD-16P1
ThermalTake TR2-430NP 430W Power Supply
I guess my best guess at this point is that the mobo is dead...but the chances of it dying at the same time as the old hdd failing is pretty bad...
frankly I'm never buying a desktop (or parts) again...I've had so many problems over the years despite being a computer junkie...and the fact that you can't swap parts much anymore since everything is integrated and a new architecture every few months kinda kills custom building on a reasonable budget...nothing works right and microsoft charges custom builders like me more for an OS...looks like cheapo laptops for me
anyways, if anybody could offer any help it would be greatly appreciated.
Thanks,
WeezelDS
Sempron 3400
WD3200 (320gig)
Thanks,
WeezelDS
