Cannot increase CPU Voltage past 1.4 - Foxconn 6150
RanceJustice
I noticed I was driving my thread in the SFF section off topic, so I decided to make a new one here.
As you can guess from the title, I'm having difficulty raising CPU Voltage (Labeled as "Hammer FID Voltage") on my Foxconn mATX 6150 board. My proc is an Opteron 165 that I've successfully put 1.45-1.475v through on my previous board. However, this time things are rather odd.
In BIOS, I see all the normal voltage measurements, from 1.350 stock to over 1.5. I can toggle it easily to 1.45 or 1.475, and sucessfully boot into Windows. However, both CPU-Z and Speedfan continue to read the voltage as 1.39/1.4. Wondering if it was just part of the reading, I attempted to overclock my proc as planned with Clockgen, and reached a similar "wall" of about 2.4ghz as when I used 1.4v on my old board. I had to up the voltage to 1.475 to get it stable at 2.5ghz there, so all signs seem to point to the fact that my board simply isn't raising the voltage here. Any idea of why that may be?
Also, in the BIOS besides the familiar CPU voltage there's also something labeled "Vcore" and has incriments in + xx mV - is this the chipset voltage?
I hope the board isn't borked. :(
the vcore option below the hammer vid control will ad more voltage to your cpu, ie if the hammer vid was set to 1.50v, and the vcore was set to 125mv, your vcore would be 1.625v. try this to see if you can raise your voltage this way. also make sure that your cmos jumper is on the correct pins.
Thanks! That actually worked! Though, for some reason adding 60 mV to 1.4v seems to equal 1.440v. Seems like an odd way to increase voltage. Essentially, the Hammer FID Voltages above 1.4 don't work.
Pretty much. There's no 1.45v option, which bothered me. I hope a future BIOS update helps fix the voltages.
