I recently built a basic HTPC vista machine, and for some reason, when I try to share the folders on Vista, the XP machine cannot get access to it.
On the XP machine when I go to "network neighborhood" it sees the Vista machine. The same for Vista when I do the same thing, it can see the XP machine.
Everytime I try to click on either machine to access the "shared" folder, it kicks back access denied and that the admin has to grant access.
I currently have ESET smart security installed on both systems. I have Windows firewall turned on on both systems too. I tried to turn off Windows firewall and disabled the ESET firewall + anti-virus and still not letting me through with the XP machine and vice versa.
I know it has to do with either a firewall issue or permissions, but I can't figure out what exactly I need to do.
I have a shared folder on both XP and Vista machines. A bit off topic but I also have another XP machine and both XP machines can see each other and also access shared folders.
Before I installed the ESET, the XP machine was able to get access to the files, and I guess after I installed ESET is when I started to get the access denied.
I can ping the vista machine and I can also remote in using remote assistance.
Any ideas or suggestions?
