I recently purchased an Alienware desktop for my girlfriend. It's the Auroa 3500 and has the following specs:
If I turn everything up to the maximum I can get such a faint hint of sound that I have to have osmething extremely loud on just to barely hear it. I've verified everything is in the correct ports and is setup properly in the system.
I've verified that mute is off and the volumes are way up. I have re-installed the drivers. I have even booted to a LiveCD of Knoppix which found the correct drivers but did not work.
At this point I figured it was a hardware issue with the audio controller on the motherboard (I tried 2 sets of speakers and 1 pair of headphones with no luck).
I went and installed my Santa Cruz sound card into this new computer with the same result (couldn't hear practically anything except for a faint whisper of sound if it was cranked all the way up). I've verified that this card works fine but when installed in this system it doesn't.
What's going on? I'm so confused as to what the issue could be now that it does it with my PCI sound card. There are only 2 things I can think of that would cause this weird situation:
Any recommendations? I'm pulling my hair out at this point!
- ASUS A8N-SLI N-Force 4 motherboard
- Athlon 64 3500+
- 1GB of DDR PC3200 (X2 512MB sticks)
- EVGA Nvida Geforce 7600GT
- Some really weird motherboard issue with sound
- Some sort of setting (possibly in the BIOS) that needs to be changed that I cannot find
