Ok guys, this issue might need some fairly expert help! I do not come empty handed though, since my last thread "Worth the tradeoff?" I finally understood the last thing I needed to understand about OCing and I have read OCing guides, etc, etc. In fact I have read threads regarding the OCing of systems almost identical to mine.
Yet, I cannot achieve even a slight OC.
I underclock everything:
LDT:600 (HTT Freq)
Mem FSB: 166
Command Rate: 2T
Mem timings: 3 clocks (instead of 2.5)
which all works fine and reports correctly in CPU-Z
then I increase the FSB (HTT actually) from 200 to 210mhz and it boots fine, but dies in Prime95 very quickly (but only in one copy... i think usually Affinity 0).
Now the vcore is highly unstable, indicated in CPU-Z as jumping around from 1.324 to 1.39, but the default should be 1.350.
Here is the kicker, and the reason for my thread title:
as soon as I alter the Vcore to anything (even setting it manually to 1.350) my machine won't even fuxing post! I figured increasing the vcore might help stabilize it for prime95, but no it seems i can't. Maybe an RMA is in order. Im hoping you experts out there can point out that im just doing something dumb.
My system:
4400+
evga SLI mATX 131-K8-NF44-AX mobo (i've even read a HUGE thread on this mobo here at the [H]ard Forum)
2*1024 OCZ platinum DDR400
Enermax Liberty 500w
QPack
P.S. I quote from Operaman who has this mobo and Opty 165 and Mushys:
"CPU FSB: 278 Mem FSB: 166 Voltage @ 1.525v (though it is seriously undervolting) and mem voltage @ 2.85v (Mushy is rated to 2.9 so what the heck)"
I never messed with my mem voltage....
http://www.hardforum.com/showthread.php?t=1023993&page=7&pp=20&highlight=sli
LDT:600 (HTT Freq)
Mem FSB: 166
Command Rate: 2T
My system:
4400+
QPack
