JDietrich07
- Aug 22, 2010
Hey all --
I have an old Toshiba Portege M400 that has all sorts of issues -- dead battery, failing hard drive, case damage... -- the sum total of which make it really not worth the effort and money to revive the computer to a workable state.
What I'm wondering is whether there's any way to cannibalize what's really the only quality part of the system that still works well -- the screen -- and do anything with it. Ideally, it would be an external touch screen display that I could plug in to my laptop and use on my desk. Getting the screen detached from the old laptop will be easy, but it's the doing something with it after that stage that's giving me trouble. There are a few major obstacles that I've identified and don't know what to do about:
I did a fair bit of Googling, and couldn't find anything about doing this sort of thing. I'm not sure whether that means it's impossible, or just that nobody's ever happened to write a guide for it before.
Also, if there is a different place I should be starting this discussion, please point me in the right direction. I'm not too familiar with tech and hardware forums, so it's quite likely that I'm entirely in the wrong place.
Cheers!
Jeff
- Supplying power to the screen
- Getting RGB input
- Reading touchscreen input on the new computer
Cheers!
Jeff
