can you use TSAA with AA?
I have a 7800gtx and i was just wondering if it does any good to set the AA to like 4x or 2xQ, and then turn the TSAA to multisampling, and the gamma AA to on. Do all those AA techniques conflict with eachother and end up not doing anything but slowing the fps down? This is with AS set too of course :)
that's how you enable the TR AA level
you turn on either MSAA or SSAA, if you aren't running any level of AA in the game you won't get any AA, if you set the AA level to 2X in the game then you'll get 2XAA MSAA on polygon edges as you normally would and then you'll either also get 2X TR MSAA or 2X TR SSAA on alpha textures depending on which mode you have selected, if you run at 4X AA in the game then you'll get 4X MSAA on polygon edges as normal and then 4X TR MSAA or 4X TR SSAA on alpha textures
I always opt to use the in-game AA settings if they are there first, if no in-game AA settings exist then force it in the control panel
