I am about to build a system with 8GB memory (for Photoshop, it's a case of the more RAM the better), and need to know whether I can simply physically install the memory, or whether I need to change the motherboard BIOS settings. I will need to flash the motherboard BIOS to get it to recognise the processor, and have read elsewhere that after flashing the BIOS I should "set the memory voltage and timings as per the manufacturer's specifications". However, I had understood that with SPD, the voltage and timings are usually automatically set to the manufacturer's settings.
Any advice would be very welcome.
NB.
NB.
- I will not be overclocking.
- The main components of the system are an Abit IP35 Pro, a Xeon X3350 (equivalent to a Q9450), and 4 x Crucial Ballstiix 2GB DDR2-800 CL4 (BL2KIT25664AA804.16FE5).
