Can you help me decide?
larrys2006
I am getting a GIGABYTE X570 AORUS Master with a Ryzen 9 3950X and a AMD Radeon RX 5700 XT or a
Nvidia GeForce RTX 2070 Super and I am looking at theise units brands what do you like best.
EVGA SuperNOVA
seasonic foucus
EVGA Supernova G3
Seasonic Focus Plus Platinum
Corsair RMX
Seasonic Prime
Corsair AX1000
cosair ax1600i
What is your budget? What features do you want/need? You should be looking at a 650 watt PSU with that setup.
Since the PSU is the 1 item in your whole build which affects every item in your build it does pay to invest in the best quality one you can get. That said, any of the Gold 80+ or above from those mfgrs would suffice for your build.
I have a strong personal preference for Seasonic. Their stuff is really solid. I've built a large number of machines for friends, coworkers, and even strangers (when trying to augment income). Never ever had a Seasonic PSU be an issue.
Currently running a Prime Titanium. Now of course the Titanium rating is pretty much silly, the difference between that and Platinum on the energy bill even here in eye-watering $/kWh CA is moot. But I wanted the best, and Because I Am Worth It.
Reactions: blkt
I ran a Corsair 750W PSU based on a Seasonic 750W PSU for 8 years, 24/7, with overclocked hardware, it didnt miss a beat and is still serviceable.
It was replaced with a Seasonic Prime Ultra Titanium 750W.
I expect a similar experience.
Dont mess about, get something decent with a long warranty. You get more stable power and better protection
Its cheap over the long term with no need to worry about harming your hardware and you get peace of mind
If you overclock, the PSU wont hold you back as long as you chose the power range correctly.
And as pointed out above, better efficiency will give you some $ back.
Reactions: blkt
Pick a Seasonic 650w+ PSU with 80+ gold, platinum, or titanium, and the warranty length you desire and call it a day.
