Can you help build a desktop
Chodam
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? Gaming & I also have an 32" LCD that I would like to plug in it.
2) What's your budget? Are tax and shipping included? 900, yes
3) Where do you live? Tucson
4) What exact parts do you need for that budget? Everything
5) If reusing any parts, what parts will you be reusing? none
6) Will you be overclocking? no
7) What size monitor do you have and/or plan to have? 21-23"
8) When do you plan on building/buying the PC? Two weeks max.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? SLI
10) Do you already have a legit and reusable/transferable OS key/license? no planning on getting windows vista 64 home for windows 7.
Notes: AMD processor either opteron or phenom x4, I'm thinking of a 9800 nVidia with Native HDMI, Any more questions just ask =), I would prefer a newegg wishlist as a link. But if not thats okay.
Guaranteed to meet your needs and budget
CASE/PSU - Coolermaster Centurion 5 + Coolermaster RS-600Watt Modular for $129.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.208525
CPU/VIDEO CARD - AMD Phenom II X4 940 + Sapphire Radeon 4890 1GB for $349.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.206747
MOBO/OS - Gigabyte GA-MA790X-UD4P + Win Vista Home Premium 64 for $214.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.205067.13-128-387
RAM - G. Skill 4GB DDR2 1066 for $49.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
HDD - WD6401AALS 640GB 7200 RPM 32MB Cache for $74.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
OPTICAL - SAMSUNG Black 22X DVD+R 8X DVD+RW for $25.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151176
Total: $845.91
Shipping: $10.06 on UPS 3 Day
Grand Total - $855.97
I would rather not go over budget because I am using some of my student loan for it. But if it is the right computer for me, I will have to consider it. Also, If you could you an nVidia card I think it would make me fall for it =) lol
For simplicity's sake, just stick with lt_shiro's build. It's one of the better compromises between quality parts and low prices.
However, the 512MB HD4870 may lag in some games if you try to max out the visual settings. Until you could afford a better card, like the 1GB HD4890, keep the visual settings on their default levels.
