Stupid_Newbie
- Dec 4, 2005
Hello,
I am in the market for a mac mini. Though im not sure of my overall needs as far as level, just going off impressions I get. I have been trying to hold off for a Ivy refresh, and im just wondering if building a mini equivalent is remotely possible?
Ill answer sticky, and we can go from there...
1) What will you be doing with this PC? Media Server with NAT for storage, light use (web, photos etc). Home automation software server.
2) What's your budget? Around what a mini costs say 11-1200CDN pre tax, post ship.
3) Which country do you live in? Canada
4) What exact parts do you need for that budget? The puck (its not really a tower), Motherboard, Ram (if 8GB out of tower dont work, i can spare 8 from tower, 16 is overkill), CPU, PSU, Case
5) If reusing any parts, what parts will you be reusing? Possible Gskill Ram, 2x4GB DDR3 1333
6) Will you be overclocking? No need
7) What is the max resolution of your monitor? 1920x1080
8) When do you plan on building/buying the PC? Anytime, im ordering my HA equiptment, and would like to start playing with it, and programming it for my house build. Though Im not in my home for atleast 8 months. Though I have a lot of programming, and screen building etc to do.
9) What features do you need in a motherboard? None really. Reliable, robust, onboard gigabit (but thats pretty standard), maybe USB3 for future proofing.
10) Do you already have a legit and reusable/transferable OS key/license? No
im not sure what I need honestly as far as power. Though I dont think the base model has me covered with the 2.3 i5. I can upgrade the ram to 8GB (or 16GB unofficially), though im concerned if a 2.3 dual core i5 will cut it for itunes, a few other programs in the background, and HA Software on the VM, along with light internet use from wife. I can go for the mid range, but I dont need the dedicated GPU, though I can go up to a 2.7 i5, again dual core. Though not sure i need the server with the quad core i7 2.0. Though server removes the dedicated graphics. I just dont have enough experience with VM (never had one myself, just co-workers on thier field laptops), so im not sure how they are on resources or CPU.
I plan to run this machine next to current, and leave the current off (as it currently goes 24/7 with itunes open for apple TV), and use a KVM to switch back and forth if needed.
Is it possible to build a mac mini?
