Can Xeons run in single mode?
danimal
I want to run a dual xeon setup but at the moment I can only afford one. Can they be run in single mode?
it depends on the board, check the mobo manual but i thought most dual processor boards were able to run on only one processor
Most should work with only one. Check the manual, but usually you have to put it in Socket 0
My Socket 604 Xeon board has two sockets. Currently, I'm running on only one processor, and the board works perfectly fine.
My dual Xeon board doesn't need a terminator, it worked fine in single mode for all 5 minutes I ran it that way :)
Yea should able to run it with out using 2 precessor, but to make sure ask before buying and read the manual for the motherboard.
