Can varying voltage damage an X2?
Hi. My motherboard seems to like giving my X2 slightly more voltage than what I ask it to. It fluctuates between being slightly above what I set it to, to noticeably more. Example:
I set my vcore to 1.4375v, and according to the BIOS and Lavalys Everest the actual vcore is anywhere between 1.45v and 1.47v. If I set it to 1.45v it sits between 1.47v and 1.49v. Can this damage my CPU? Is there any way to stop it?
Thanks.
unless you are using a good voltmeter measuring off the board or PSU itself - I don't think you can completely trust the software readouts. Mine does the same thing by the way.
you're already running it over stock voltage, i don't see why you'd be concerned about a little more :p (stock is either 1.3v or 1.35v for X2's)
how hot is it running, and what mobo do you have?
thanks for the reassuring replies. i get the point about how i'm running it over stock voltage anyway heh.
my mobo is an a8n-sli deluxe (i'm considering getting a DFI SLI board for the extra overclockability, i have one in my other PC and it rocks) and the highest it got to at ~1.42v after 9 hours of prime95 is 59c... but i live in a very hot place and it's 38c today. cool by my standards :p
another quick one: what's the highest temp i can safely tolerate and whats the highest safe vcore for an x2 4400? also same question (-temp) about the RAM.
i can hit 250mhz on both (250x10 cpu, 1:1ram, 4xHTT) at 1.47v and 2.85v respectively but it fails prime95, so how much more juice can she handle, captain?
thanks
First off don't trust the software/board sensors too much. To be certain grab a multimeter and probe your board.
Second, if the board is overvolting, then set the volts lower in the bios then what you want and let it overvolt to where you want it to be. The fluctuations though, that could cause instability.
Just be sure the voltage is not fluctuating above the max you would want to give your CPU.
k, i just finished ~5hrs of prime95 (x2) coupled with winamp running. also finished superpimod 1.4 1M and 8M. i'll call it stable for the time being.
i've done exactly what you guys have suggested. i've got the vcore set to 1.425 which the BIOS and software apps thinks is 1.456v.. i've hit the limit at this voltage (248x10) so i'm wondering what the odds of it melting are with 1.4375vcore (1.47-49v) are...
That voltage is normal. Regardless, it's the temps that matter. 59C is a little higher than most people around here will recommend... it's in a shady range. If the chip is stable, it's stable. You can make arguments for high temps 'shortening the life span' of your processor but that's not something anyone can prove. So it's up to you whether or not to run your processor there . Better cooling is certainly an option
