I have searched this site and many others looking for a way to "split" or mirror data from an USB device (bar code scanner)to two computers. We need to do a parallel cut-over from a legacy asset management system (whose interface, at each loading dock, is a LAN connected PC with an USB bar code scanner) to a WEB application using a laptop with the same USB scanner. Years ago I designed a RS-232 serial port Y cable that allowed the SMDR data from a PBX to go to both a data capture serial port on a computer and another device by utilizing signal diodes.
Not anticipating the firmware/software/timing and control logic involved, I thought all I needed to do was match a pair of diodes that would block the computers from sending or receiving data from each other, as I had done before. USB is much more technologically complex.
All the research I have read, so far, leads me to believe that I would have to design a "black box" which would interface between the scanner and the two computers. The box would look like a computer to the scanner, a scanner to each computer, and thereby spoofing each component. I dont think I have the technical chops to get this done in a timely and efficient manner if at all. Though if anyone has done this before, please share the details. Im very good with making things work from a plan/schematic etc.
OR: Plan B seems to be to share the USB port in either Windows XP Pro, Windows 2000 Pro or Windows 7 Pro. I would need to have the windows for the resident app. and the browser (running the WEB app.) simultaneously read each scanned barcode. I am not sure how to do that either.
I hope that Ill be able to find someone with a workable solution to this question. Thanks, in advance for your helpful thoughts and suggestions!
