Some people are overreacting...
Backup your data, sure it's always a good idea.
But your drive has 1 single reallocated sector. Your drive has hundreds of spare sectors dedicated for this exact reason.
As long as reallocated sectors is not continuously increasing it's fine.
I have a drive with 16 reallocated sectors. It got them 3 years ago and yet the drive still works perfectly fine and it's still at 16 today.
There is nothing to repair, the drive already repaired itself by reallocating a bad sector to the spare sectors part of the drive like it's designed to do.
And I had a drive that had two and died within a week. All experiences are different.
OP-back it up and don't save anything to it you aren't willing to lose. That's not a ever reaction.
I'm just saying you can't look at 1 reallocated sector and make the conclusion the drive is "dying fast".
Q: I'm checking my disk with chkdsk or scandisk and they are reporting bads, but MHDD does not see any bad block. What happened?
A: Your drive had some bad blocks in the past and they were removed by MHDD or other software (or sometimes by the hard drive itself).
1. Use DiskEdit to remove bads from your file system
2. Try Partition Magic's "Bad sectors recheck"
3. Repartition your hard drive.
Q: Does MHDD Scan+remap kill my data?
A: Remapping with MHDD is safe to your data as long as you have not too much bad blocks (under 100).
Once they are empty maybe the can be fixed and be put back in use?
