Can SyncMaster 730BF be fixed?
sanderm
My old display seems to be dying. Depending on a day, it takes like 20min for it to turn on display. But some days it has just blinking power on indicator and won't show any picture. Or when all my displays (just displays, not computer) turn off because of I'm not using it, it takes quite some time to get that old display to show any picture again. Once the display turns on, it works like nothing is wrong.
Sure it's an old display, but maybe there's an easy fix? What could be causing the problem and can it be fixed?
Try checking the power brick to make sure it is putting out the proper voltage. I have the Syncmaster 750 that ended up needing a power brick replaced. It would do what you're describing as well as just randomly turning off every once in a while. It may not solve your specific case, but it's worth checking into even if only to eliminate it as a cause.
