I've been driving myself crazy over the past few weeks trying to find a decent Wireless-N router that works reliably. I had a Netgear N600 v1 that worked great until it died in an unfortunate encounter with my cat. It had great range and flawless performance for the ten months I owned it. Unfortunately I can no longer find that router anywhere (I've been told the N600 v2 is nowhere near as good?)
I've since been trying to find something that can replace it. I've pretty much given up on any of the 450Mbps routers. I tried the Linksys(Cisco) E4200, Belkin 750DB, and Netgear WNDR4000. The results all seem to be the same, i.e. lousy range (especially useless at 5Ghz) compared to the N600 and constant dropped connections. I also tried all manner of network adapters on my PC's, but to no avail. I think the next time I show up at BestBuy to return yet another router they are going to ban me for life.
So, am I having a bizarre string of bad luck, or are all 450Mbps routers just garbage? Should I go back to a cheaper 300Mbps router, and if so what would you recommend?
