Get a Draft-N/MIMO router. Far superior range over old G. And you don't need a G adapter to benefit from the increase in range...even antiquated old B adapters will still received the boost in signal strength/distance.
I still say some of the older WRT54G (V1/2/3) routers are hard to beat.
this is a VERY naive statement. Draft-N (at least, the draft these routers are based on) is VERY VERY different than the current drafts and will even further different from the final revision. I'm a peer review member of IEEE ComSoc, so I've seen a couple of the drafts come my way for peer review. You will serve yourself much better by buying a good, quality A/B/G router now than invest all the money required in a draft-N router and network cards and then have to replace it all when the final revision is released (which, at this point, doesnt look likely to happen until sometime mid-2008).
Well said.I don't believe so at all. Why? Because for the past couple of years...since I've started using MIMO routers....my clients get to benefit from the increase in range of them. I can use a single AP instead of dealing with several old G units which would be required to blanket an area. I don't have to deal with complaints of "I can't connect when I'm in the room down the hall", or "I can't connect from upstairs".
The mistake people are making...is thinking that when "N" becomes official and hits the store shelves, that current Pre-N and Draft-N routers will simply cease to stop working, or will not be compatible with existing clients, or blow up or something. They won't. Most people are using them with adapters that are just "G" anyways.
On top of this...look at how cheap units are? Barely a hundred bucks...or a hundred 'n fifty bucks for nicer ones. Purchasing one now..and enjoying the huuuuuge increase in range and excellent daily performance of it for the next 2.5 years with my current Centrino G chipset is a no brainer. When "N" becomes official and hits the stores...by that time..if my router isn't upgradable...and for some reason I insist of having official N at that time..it's a no brainer to use a little pocket change and purchase a new one. Computers and peripherals have gotten so cheap, it's not like you're spending 1800 bucks on an entry level AP here.
i have heard ok reveiws on the belkin draft n, but would be a extrememly good g?
