Postal Dude
- Mar 15, 2005
Ok this makes no god damn sense whatsoever! A64 3200+ runnin at 2.4Ghz memory at 200mhz 5:6 divider 3.3%OV idle is about 39-41C load is about 44-46C
Same A64 3200+ runnin at 2.5Ghz Memory at 208Mhz 5:6 divider 5% OV. Idle 37C, Load 44C
The bench used was Prime95 Small FFT torture test. Ran on the same day about an hour apart.
I'd say the ambient temps are about 16-17C
Surely with more Mhz and more volts, would come more wattage and more heat??
