can someone help me pick a case...
nightwalker
basically i want a case that has a nice big window ( with no fan on it ), and easy to put watercooling rads in ( like no drilling out more holes in the case ).
i was looking at the lian-li pc7 series and they looked quite good, i only wanna be able to fit a 240 or 2 x 120 rads in it.... i was looking at the v1000 but i just cant justlfy spending like 220 bux on a case... i only wanna spend like half of that roughly up to bout 140 ish.
any other ideas out there ? ive already had a danger den waterbox and im telling you... after you've used that alum key with like 7 bolts taking the front panel off a few times it makes you wanna scream:eek:
thanks in advance..
