Can someone explain what 1t is
Err i guess its the HT speed. like 2000mhz is waht my proc is. but am i runnning at that and what is it!
I'm guessing it's the memory timing, Command Rate 1T AKA Command Per Clock. If using an Intel system, it is only configurable through the BIOS, but your A64 system can use A64Tweaker or A64Info (more up to date than the former) to change it as well as other timings. It won't stick after reboot unless you use the settings save function in A64Info BTW, but if you can find it in the BIOS, it better damn well stick.
Be forewarned that CPC can lead to instability particularly with larger memory loads (2x512Meg/1Gig or 4xAny Meg). It may require other timings to be loosened, higher driving strength and/or more voltage to the memory or wherever the memory controller is located (NB chipset for Intel, VCore for A64).
If it's some other 1T, then oh well.
