Can someone explain to me active-outputs?
Kryst_20
I have a DMUX with 4 active low outputs.
Im assuming the truth table for the SELECT lines are:
0 0
0 1
1 0
1 1
From my understanding, the outputs are Active-low aswell. If apparently you get an output of 1, it is run through a NAND gate, which typically would demote the 1 to a 0.
Why would a decoder only set output to zero?
Isnt a decoder something that can decode binary input? If every output is zero, what makes it a unique output?
Did you register here just to get help with your homework? Might want to check with your professor first. I'm sure he would be willing to help.
About the demux. If the demux is active-low, then all outputs should high unless selected. The selected one would go low. If you draw out the gates for your demux then you should be able to see this. If they are all low independent of the input then the device is not a demultiplexer.
