I ran two 7900GTX's against each other to compare speeds and scores and to see if they came up any different.
The first card (Card "A") idles around 42c and loads at around 68c.
The second card (Card "B") idles around 37c and loads at around 62c.
They are identical in every way.
Stock cooling for both.
CPU Speed exactly the same as well.
Card "A" clocks at 710Mhz core / 1765Mhz Memory - 12462 score in 3dmark05
vs
Card "B" clocks at 730Mhz core / 1850Mhz Memory - 12412 score in 3dmark05
How / why is this?
Any explanation would be appreciated.
If that explanation were kept simple enough for a 3rd grader to understand - that would be appreciated even more.
Thanks.
vs
How / why is this?
Thanks.
