I've just purchased this card: Intel EXPI9402PTBLK PRO/1000 PT Dual Port Adapt NIC
It's a PCI Express (x4) dual-port gigabit network card that supports "teaming".
I'm going to be using it on my home fileserver but I'm not sure if (or how) to use teaming.
For example, if I'm transferring a file to my fileserver using full gigabit speed than other connections to the server will be slowed down. If I use teaming, can I somehow use the other port on the NIC to have another full gigabit connection that shares the same IP as the first port?
How does this work? Do I just connect both ports on the network card to my switch and then enable teaming in the driver or something?
