I've got an Antec P182 which is one of the few cases (800D and TJ-07 are the only others IIRC) to have a dedicated power supply chamber. The idea is to keep the CPU and GPU heat in the top chamber and keep the PSU in the cooler chamber so its fan doesn't ramp up as often.
It would be a nice space to stick a single 120mm radiator in though. If it was on the side of the case, exhausting heat out, would the radiator itself dump any heat into that lower chamber?
