Apparently nvidia released a beta driver this AM that has a mistake in it allowing mixed GPUs and physx.
They quickly corrected it.
But if you can find someone with the original drivers, I think you could do it.
Read all about it: http://hardforum.com/showthread.php?t=1522011
Yes. I'm running 2x Sapphire Vapor-X 5770s and an EVGA 9800GTX+ for physx under Win7-64bit right now with Catalyst 10.4hotfix and 186.xx drivers respectively. Works great.
Thanks for the reply.
Just wonder how well a GF220 GT with 1 gig ram will do physix....
might as well not have one. physx is processed by shaders. it's the only spec that matters for physx. 220 only has 16 of them. it won't do jack.
its not false advertisement directly, or bait-and-switch at all, its they dont shout it because they know people would be upset. their reasoning behind it is to ensure driver compatability, as they only test their drivers to work with their cards, they will not guarantee their drivers and cards will work with their direct competitors products, so they disable it.
a crappy situation to put the customer in? sure, but they arent doing it soley to screw ATI owners.
then you're pretty much verifying that you understand that and don't expect Nvidia to take care of you.
