Technically yes, but but but... since you neglected to say where you acquired the RTM build of Vista x64, well... it's bordering on a legal question at this point.
Also, if you don't have the hologram CD to use for installing, or you're not using a backup disc made directly from the hologram CD the customer should have or the manufacturer provided media, then yes it is most certainly illegal.
i have a genuine paid vista 32bit ultimate, key. and i also have a 64bit rtm copy, will the key from the 32bit edition work on the 64bit edition rtm download copy i have? (i haven't tried yet)
I didn't feel like waiting for the x64 DVD so I downloaded it at work. I probably will order the x64 disc just to have a "genuine" copy. I don't mind the small cost since the Power Together deal cost me nothing.I had the RTM and then I got my disc from the PowerTogether deal. I ended up using the key and installing x64 Business from the RTM disc. Its legal to do it since the 32 bit key works for the 64 bit version. Obviously not legal to have the RTM if you got it thru bittorrent or some shit. But I went and ordered my x64 disc anyway.
So you broke the EULA of all the editions of Windows you have on that DVD to do your job - it's against the EULA to modify the code of any Windows distribution media to create such discs.
The sticker isn't the end-all-be-all factor in this; it's tied to the hologram media.
Talk about a hack job... methinks this thread is gonna have a short shelf-life...
