Ok so I just finished putting together a new machine and have been installing device drivers and I have what I believe all drivers installed but for some reason I have in the device manager one Unknown Device. Below is what is currently installed in this machine:
Asus M2N32-SLI Deluxe Wireless
AMD X2 4600+ AM2
BFG Nividia 7950GX2
X-Fi Platinum
Lite-on DVD burner SHM-165H6S
Logitech G15 keyboard
Logitech MX510 mouse
Seagate 7200.10 320GB HD
OK I disabled the following in the BIOS because I do not need these devices:
silicon SATA device
parallel port
onboard audio
nvidia raid
The following drivers are what I have installed:
nForce SATA, ethernet, smbus
nvidia video drivers
x-fi audio drivers
AMD Processor Driver including CoolnQuiet
Logitech G15 keyboard drivers
wireless driver for the builtin wireless
This system is on 32bit XP SP2, note I slipstreamed SP2 + hotfixes and the Nvidia SATA drivers. The rest was installed afterwards. I did not install any USB 2.0 drivers because I understand that those drivers have been added to SP1 and later.
In looking for what this Unknown Device could be I viewed the device manager by Connection instead of by Type. The unknown device appears under the ACPI branch and at the same level as the System Board device. Note it does NOT appear under PCI or USB. However not too sure if the connection listing is accurate if the device is unknown.
I know long post but trying to give as much info as possible for help. Any suggestions are welcome.
AMD X2 4600+ AM2
BFG Nividia 7950GX2
X-Fi Platinum
silicon SATA device
parallel port
onboard audio
nvidia raid
x-fi audio drivers
