Computer cannot power on, as described in this post.(When I press the power button, nothing happens. PSU does'nt start. (It jump starts fine)
Now The problem is likely either mobo or cpu. Because I removed everything else from the mobo. (except cpu) .
I'm planning on removing the CPU to find out the problem.That's why I'm asking the quesiton. If the a normal mobo should still power on w/o CPU, and in my case it doesnt' , then I can make sure i'ts a mobo problem and RMA the mobo.
