Can it fit?
sdk
I am running an asus p4pe mobo with a 9100 and 512 pc 2700 ram. I am going to be getting a 9500 with a Zalman heatpipe.
When I look in my case, where my ram is in the 1st dimm the clip is about 1 mm away from the top right of my upper memory. IF i got the zalman, would it fit? Can I move my memory over?
THanks
post a picture of the motherboard. That would give us all a better idea of what your dealing with.
HOwver I wouldn't assume that it will interfear with your RAM. The Zalman really isn't that big. It looks much bigger then it really is.
