sitalchauhan
- May 30, 2006
I am only planning to put one 8800gtx in the bottom pci-e slot of the P5K for space convenience, instead of the top pci-e port.
Does it make any difference between which port I use? Is it ok to use the bottom port instead of the top one?
I read that if you use 2 gfx card on this board, then one will run at 16x and the other at 4x. This just made me think as to wether the top port is 16x and the bottom is max 4x... Or is it that if using one gfx card, whichever port you put it into it will run at 16x?
Thanks
Thanks
