Can I use 2 ssd?
bitibomer
i have a PNY 240gb ssd(have windows 10 on it) and a 128gb crucial(that i just took out from my cousin computer). i want to use 2 ssd, can i?. im installed the ssd and i initialize the ssd, but when i initialize the ssd, it's said that IO error some thing. Help!
You can use as many SSD's as you can normal spinning hard drives.
Give more detail about the error. What do you mean by initialize the ssd? Be specific about the error.
Get the Crucial Storage Executive utility to check the health of the drive.
You may have a faulty SSD.
However, you can try cleaning it with Diskpart to see if something is just messed up.
open up an admin command prompt and enter these commands
diskpart
list disk
select disk (whatever the number of the disk is - looks to be 0 from your screenshot)
clean
create partition primary
format fs=ntfs quick
If that doesn't work, then the disk is hosed.
Last resort is to try a firmware update on the drive.
