Can i turn it off
forrehmmnd
ok, the northbridge fan in my system is the loudest thing in there an drives me nut. the mobo is in my sig and the NB is the nforce 4 ultra.the hsf attached is about 1.5 inchs tall with a 1.75-2 cm fan. is it safe to turn the fan off or will i burn up my chipset. i have looked at other coolers but the mounting is in a way that i cannot find one that will mount correct even with modding. so again, can i leave it off ?.
You haven't listed the motherboard in your signature.. But as a general rule of thumb, it isn't okay to switch off the NB fan. If I weren't needed on stock cooler, it wouldn't be there.
woops, coulda sworn it was in there, its the ecs kn1 extreme. yeah your probably right. i shout probably keep it on. i will continue the hunt for one that fits.
Try either an HR-05 or an HR-05-SLI chipset cooler. If it doesn't cool well enough passively, you can attach a low speed 92CM fan to it.
it doesnt fit and it wont mount correctly.i have my scythe ninja in there and not much else fits in that area. any suggestions ?
Get a different fan. Pick up a low speed 60mm or 80mm and just mount it blowing on the northbridge heatsink.
