Can I Stress Test a 6970 With a Dated CPU/MB
r0b0t
I found what I think is a great deal for a refurbished ASUS 6970 (DirectCU II 890MHZ 2GB 5.5GHZ GDDR5 2xDVI 4xDisplayPort ) at $224.00 CDN, but the warranty is only 60 days. I wasn't planning to upgrade my system until next year, but I am thinking about jumping on this card. Would I be limited in my ability to stress test it on a Q6600 @ 3.2 GHz? Or is it stupid to even consider buying a refurbished video card at this price? I plan to get something along the lines of a 2500K (and MB and RAM) at boxing day that this card will be used with.
I apologize for not having detailed specs, I am at work and can't remember the MB or ram I am using.
Thanks in advance for any advice!
Memoryexpress clear out? Use furmark or kombustor, it should give you an idea how it's handling itself. The main think you are looking for are things like graphical glitches/temps anyway, should be fine for that.
