Hi,
I would like to know if following components from my current computer are suitable to be 'savaged' into a HTPC (and give me a reason to ask permission from my wife to build another PC
Athlon XP 2500+
Chaintech 7NJL3/4
1 Gb RAM
Inno3D FX5600
80 Gb Harddisk
Some rubbish case & fan... and a noisier-than-jet-engine CoolerMaster CPU heatsink which I forgot the model number.
1) What components should I change/ add?
2) I am thinking to use that mainly as a DVD center. If I add a capture card, will I be able to record TV programs using the computer? Is it possible to have something like a timer function?
3) The TV I have now is a Philips plasma that can only do 1024 x 768. Will playing DVD via TheaterTek with FFDShow have some significantly increase in quality than a regular DVD player?
4) I am not planning to OC (don't think OC'ing is necessary for HTPC). Which cool & quiet CPU fan should I get?
I would like to keep $ at minimal but am willing to spend if there is a need to change. Hopefully something less than US$500.
Thanks in advance.
Athlon XP 2500+
Chaintech 7NJL3/4
1 Gb RAM
Inno3D FX5600
80 Gb Harddisk
Thanks in advance.
