renswic
- Nov 28, 2004
not sure if this is hte right spot, if it isnt feel free to move it
guess ill post the specs first, again not sure what info you all will need so forgive me if i give to much
P4 2.8 ghz
1GB of ram not sure who makes the ram and chip thou
Msi 484P Neo Mobo
PSU is a Demon Silver 480W ATX Switching Power Supply(yes its a cheapy i know, but it works atm)
cooling is a from 12mm Fan, an a reare 80MM fan, the CPU fan is this thing(http://www.svc.com/pa9c-38cual.html) my new case will have 1 other 80mm fan added to the back and maybe 1 more 120mm to the front(if it can fit)
im not looking to get earthshattering speeds, id just like to cross the 3.0 mark. speedfan shows it running at 29-30c at idle and up to 35c at load
thanks for your help
P4 2.8 ghz
Msi 484P Neo Mobo
