Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
To OC you must download a OC utility like coolbits, Rivatuner, or Powerstrip. Do a google on any of those, and be sure to educate yourself before OC like crazy.
Install it, and clock it. On step at the time. + 5-10MHz. Find max Core freq, then max RAM freq. ANY progress check in benchmarks and 3d bloodsuckingthirsty4ultraGPUs games, such as D3, HL2, CSS, FarCry. When it will start to "lag" or you will see artifacts, you need to lower your clock frequencys.
