Can i overclock my GF3 Ti-200?
87IROC Z
Topic says it all. Any good programs out there so i can start overclocking this card? Ill probably end up getting a 9800 pro once the next gen of cards hits. But this will have to get my by until then. And right now with medium settings its only getting me 25-30 fps in far cry. :(
The GeForce3 ti200 is infamously overclockable with adequate cooling.
Use the coolbits registry key, instructions can be found here.
Powerstrip is a good program, but the integrated nvidia overclocker works perfectly and doesnt require any additional install.
yeah, just use anything like rivatuner. i can take my gf3 to ti500 levels, so it's a really good overclocker
Cool, thanks for the tips. Ill start with coolbits when i get home from work. Im glad to hear it overclocks well, especially since its watercooled. :)
I managed to get my Gainward gF3-ti200 to 270 Mhz Core / 288 ( 576) DDR and it was nice and stable. If I bumped the mem to 289 it would, let's say - "spaz out". Uppping the GPU by 1 or 2 Mhz would give me a very blue screen - not a BSOD, but everything blue... odd, but I found the max stable of the thing after lots of tweaking.
Currenty in my wifes system running a "mild" 245 / 250 - gotta have them better frame rates for RollerCoaster Tycoon yah know.;)
So, yes, the GF3 Ti200 is a hella OC'er - ram sinks help, and so does good cooling - push it up little by little and see what it'll do, and yes, it does make a difference.
Peace,
Tim
i overclocked my gf3 ti200 64 to 260@490
how you push it to 270 :(
i overclocked this card to much and its burn a long time ago :)
My brother bought the gf3 specifically for its overclockability. It is the gainward model and i love giving 8500's good runs.
So far im up to 255/531 stable. Every time i go past 531 for the memory clock i get artifacts. But so far ive been able to keep bumping the core clock. Time to take a break. Hopefully i can get this even higher tonight. :cool:
Bah! My core is crapping out at around 215-220Mhz now :(. Memory goes up to about 540-545 though.. Asus V8200T2 Pure.
I've got a plain vanilla Geforce3 (200/460) at 250/540. I'm under the suspicion it might have a Ti chip under the heatsink.
Great card really.
